whit
Sep 16, 2016Explorer
Issue with window
Hi all, I have a 2005 National Dolphin. The problem is with one of the small side windows in the slide out. On the window that slides up and down there is a metal rail across the top of the glass. ...
ILVMYGT wrote:
text deleted....
If you decide to use the CLR sealant soak the tube in hot water to 30 minutes before you apply it. This will soften it and it will flow better. Also get a really good caulking gun, the cheap ones will fold under the pressure required to get the sealant out.
