Gene_in_NE
Sep 17, 2013Explorer III
j-d wrote:Yes, because these Trail-Lites are fairly light, they come from the converter with load range "D" tires and rubber stems suffice for the maximum of 65 PSI. That is why most replacement tires should be load range "E" and change of the stems to steel.
Now THAT was Providence!
Rubber Valve Stem?
burlmart - Glad everything turned out okay for you. Your experience proves the point of having the tools and tire for fixing flats with you. The responder can then provide the necessary service.
