katysdad wrote:
Also you can try unplugging and reconecting all connections as oxidation can cause a voltage drop.
I really appreciate everyone's help and wanted to get back to y'all with the solution. First off, the unite I have is not very friendly with making adjustments. I pulled the whole unit out and found the ignition, but trying to get that sucker out requires some serious disassemble. Since all was working before, I took the advice of katysdad & just pulled all connectors, made sure they were clean and had a good bite when back together. Replaced the unit and running like a champ now!!!!:B.
This unit really has no adjustments as everything seems to be sealed. I couldn't even locate the sail switch.
Anyway, thanks again. You where all a great help!!!!
