Mr_Mark1
Feb 17, 2019Explorer
Ivylog wrote:
Well, like so many things in life, there is not your normal intake manifold on the ISX. The air disappears into the side of the dohc head in the middle...doubt you could get a camera to make two 180 degree turns. Maybe there is a camera that looks sideways on a flexible rod as size would be less of a problem coming in the 4” diameter hole on the side of the head.
*I see you can buy a $25 lighted borescope with a mirror on the end.
Ivylog, I follow that thread on the other website you were referring to. Why don't you get an oil analysis to see if that can give you some info. That's how the guy that is needing is 2nd repair found out that it's happening again.
I sure hope that you never have to worry with that repair.
Safe travels,
MM.
