dougrainer
Jan 22, 2021Nomad
HighwayJunky wrote:
Found my answer after talking to a Winnebago Tech. I have a "drip" at the valve for switching from campground to Fresh water tank. When the valve is on campground water a leak still drips into the fresh water tank thus over time filling the tank. Once full the water was no place to go but out the top of that tank thru a overflow line then onto the ground. Thats it, tightened that valve,,reduced small amount of water from tank by using the pump and leak stopped..easy fix.
I told you this 3 days ago. Why go to a forum if you do not take advantage of the people's suggestions? Doug
