Vibrant93's avatar
Vibrant93
Itasca. Shore power.
Thanks for taking the time to read this. My wife and I have had our 2000 Itasca Suncruiser for 8 months or so now and have officially almost figured out everything there is to know about it! Ha, how's that for confidence?! There is one thing that I do not quite understand though. This coach (35U/Ford) has a 30amp power cord yet on the power panel inside the motorhome has a selection for 50/30/20 amp service. We've figured out that the basement A/C unit has 2 compressors and that selecting the correct amperage rating for the service provided has a major influence whether or not breakers are tripped. My question. How would we ever utilize 50 amp service if the power cord into the RV isn't a 50 amp cord? We recently went to a park that had 50amp service and I plugged in using a 50 to 30 amp reducer on my cord yet was still not able to select the 50amp selection inside the RV on the power panel. Does this make sense?
  • To add to this discussion about the Genset AMP ratings. IF you have a Genset--and have a 50 amp RV and the Genset is a 5.5 or 6.0 0r 6.5 or 7.5 or 8.0. AND you also have a 50 amp EMS system. On Genset, the EMS amp shed system will start to shed the sequence of appliances if the RV goes OVER the amp rating of the Genset. Lets take the 8.0 genset that is actually rated at 67 amps. Once the RV goes OVER the 67 amps rating and tries to draw MORE amps than 67 amps, the EMS shed system will start to shed the selected appliances in the Shed order. That is why on Genset the EMS amp display still shows the amp draw. 10k and 12.5 k gensets will actually put out 2 phase current and disable the EMS system just like on 50 amp shore power. The EMS board knows what the amp rating is of the RV's particular Genset, because the installer sets it up on jumpers on the board. This can create problems when people replace the EMS control module and do not know to set the Genset load factor for their specific genset. Doug
  • 4x4van's avatar
    4x4van
    Explorer III
    Although my 2004 Itasca is a 30A system with only a single ducted roof A/C, it had the option of a second roof A/c along with an EMS (still on 30A). So yes, an EMS IS available on a 30A coach, and in fact is pretty much required on a 30A coach with 2 A/C units.
