bjarnold's avatar
bjarnold
Itasca Spirit 31' Tires
I need to replace the 10 year old tires on my 2000 Winnebago Itasca Spirit 31ft and have a few options available. Are they all about the same quality?. The load range is all the same
1. BF Goodrich Commercial T/A 225/75/16
2. Firestone TransForce H/T 225/75/16
3. Goodyear Wrangler H/T 225/75/16
  • OFDPOS wrote:
    How much did it throw your speedo off ? As it is now ours is off 2 mph (slower) replaced the Michelins that had the recall with the defenders, but went with same size 225/75/R16 ..
    According to my satellite based navigator unit (Garmin), my speedo now reads about 1.5 MPH slower due to my over-stock-diameter Michelin tires.
    I don't care about speedo inaccuracies this small, as I'm usually under speed limits anyway. Probably a Ford dealer could tweek my V10's ECU someway to compensate for the larger diameter tires if I wanted to pursue it.
    I'd like even larger diameter tires on our Class C if it didn't make it too much of a step-up into the cab for the DW.
  • For convenience and for reference....
    CLICK HERE for Tire Rack's selection of 225/75/16 "E" rated tires. A few in the list are close-outs with limited stock.
    I realize most of you are unable to mount and balance your own tires. But the information is interesting.
    I buy all my tires from Tire Rack, but I have access to a tire mounting machine and a tire balancing machine. I do wonder if the balancer can handle the DRW offset.
  • The three tires you list are roughly equivalent, and Michelin's Defender series in Load Range E is essentially the Commercial T/A with a different tread, designed more for all-season use on lighter trucks and large SUVs. Bridgestone similarly has a tread pattern alternative to the Transforce H/T in their Dueler H/T line.
    A step up in durabilty, with substantially heavier tire bodies (and in some cases steel rather than polyester in the body) will be Michelin XPS Rib, Bridgestone Duravis R250, and Goodyear's RSA tire lines. My last tire change I put on XPS Rib tires, knowing that I will not be using the RV on snow and ice.
    Tom,
    I think it's possible to get that great XPS Rib performance and safety in a traction tire if one can get their tire dealer to order this tire for their Class C, since dealers probably wouldn't normally stock it:
    https://www.michelinman.com/tire/michelin/xps-traction
