sjverkayk
Jan 27, 2014Explorer
Itasca Sunstar 30T or Winnebago Vista 30T Owners
If you are or have been an owner of one of the above models, we would be interested in hearing about your experiences regarding the handling, instrument panel viewing and communications with the dealer, Winnebago and Ford. If you have made any modifications to make the vehicle safer, please let us know what those were, the costs and how satisfied you have been with those modifications. This is our first RV and we purchased this vehicle because we trusted the Winnebago name and, at the time, did not find any negative reviews for this model.
We have found the vehicle to not track when driving at highway speeds and almost lost control when encountering winds of about 15mph. The other issue is that you can not read the instrument panel when driving in sunny conditions due to the glare from the sun on the plexiglass. We have been in contact with Winnebago, Ford and the dealer. We have since learned that there is a weight distribution issue between the front and rear as well as side to side. This causes the front end to float at higher speeds and to pull to the drivers side. Ford says that there should be at least 35% of the weight over the front axle. Per our scale tickets, this is not the case but Winnebago states that they are in compliance with Ford specs for this chassis.
The local Ford dealer did suggest we take it to a company that specializes in RV suspensions. They say they can correct the handling issues, but when we contacted the manufacturer, Winnebago customer service rep stated that if we were to make the aftermarket suspension modifications, our warranty would be voided. We then contacted the dealer and delivered it to their service department in hopes that the vehicle could be repaired under the warranty.
So, after purchasing in August 2013 and taking two trips, the vehicle has not been used since we delivered it to the dealer on October 14, 2013. If you prefer to not post a reply on the forum, you can email us directly at winnebagowoes@gmail.com.
Thanks for listening.
