PartyOf Five wrote:
The unattended space heater doesn't sit well with me, though I'm sure you have it plugged into a GFI.
If I was on shore power and outside, I would prefer to set the furnace at 50 and expend some propane instead.
Everything else sounds great- I don't have a compressor so we just fill the lives with pink stuff, but then again, Da Moose won't be let loose until spring break (we've been winterized about 6 weeks already - 14 degrees here this morning brr!)
Is not the unattended space heater you have to worry about.
If you are afraid to use it when the RV is unoccupied.
I really would not want to use when the RV is occupied.
There are no lives involved in an unoccupied RV. If you feel the need to watch the heater. The heater is unsafe and should not be used in any scenario.
