I own a 40' DP. I’ve noticed that some RV owners use jack pads on level, hard packed surfaces, while others do not. What are the benefits of using jacks pads on such surfaces when raising the RV is no...
I have homemade pads. Two with four layers of 3/4" plywood and two with five layers of plywood. They are 16" square. I never use mine on hard surfaces unless the pad is out of level quit a bit. The pads then make it easier to raise one end or one side.
