Daveinet
May 08, 2013Explorer
From GM performance crate engine. www.crateenginedepot.com If you are a bit of a mechanic, you may want to opt for just the block and drop Edelbrock heads on it. The reason for this is that Edelbrock teamed up with GM to make the fast burn head. Fast burn improves efficiency, as well as allows for higher compression. Get the 502 with the HT cam (high torque) and then use the Edelbrock head.
If you have money to burn, go for the RamJet 502, which is what I wished I had done. For the money I spent on the Edelbrock MPFI, for not much more, I could have run the RamJet. Even though its a very high performance engine, the FI means that it still has gobs of torque in the low end - more than the high torque version.
38,782 PostsLatest Activity: Sep 19, 2026
