dougrainer
Mar 29, 2020Nomad
E05 on your Dimensions by Magnum means that there is less than 11.0 volts while inverting which means the Inverter will not Invert to 120 for your Inverter controlled appliances.
You should have a FORD chassis. The Headlight switch may have the roller that increases and decreases the instrument cluster backlighting. IF the roller wheel is rolled to MAX brightness and then you feel a "click" when rolling up, you have engaged the interior dome light indent. Motorhomes do not connect the dome light wiring to the dash switch. They may connect to a light outside by the radiator, but rarely. On Ford Chassis, if the roller wheel is in that indent for a dome light, Ford's use a relay to power the non installed light. That relay uses 12 volt chassis power to engage. THAT will draw a Chassis battery down in a week or 2. Make sure that roller wheel is not in the clicked indent. Doug
38,782 PostsLatest Activity: Aug 30, 2026
