az99 wrote:
Check the tire pressure and set to tire mfg. pressure for your actual load. Many dealers set them to 120 when they should really be at 80.
X2 And I set the front tire pressure lower than the dualls.
Also, Did you buy a longer C than your other one? Are all the tanks located in the same place? Are you test driving it and comparing it to your old one with all the tanks empty?
For me how much gas and or water you carry, if the tanks are all in the rear, will affect the ride.
I pretty much can tell when I am getting low on fuel without looking at my fuel gauge on how rough the ride starts getting.
