RZRguy wrote:
I have a 1999 32' Fleetwood Southwind and would like to tow a 4x4 jeep.
My questions are: equipment needed, hitch and brake controls?
Are there jeeps that are better than others for towing? thx
in terms of current models...a 4WD jeep that has a manually selectable neutral position in the transfer case can usually be flat towed. all-wheel drive models generally need a trailer (all 4-wheels off the ground). check the owner's manual (available free on line from jeep.com) in the recreational towing section or ask here if a specific model/yr can be towed or check
here. input the vehicle information to determine if it can be flat towed as is or if mods are needed.
beyond that you'll need a hitch, baseplate (attaches to the jeep) and an aux brake control. lots of options in hitches and you'll get lots of opinions. we use a Blue Ox hitch and baseplate and can recommend them. our aux brake is the Unified Tow Brake from US Gear.
but it's just important to know how much weight you can safely tow. in general, the maximum amount of weight you can safely tow will be the lesser of the following:
• the GCWR (gross combination weight rating) of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc.)
• the weight rating of your tow bar
• the weight rating of your hitch
this is why it's vital to know what your MH weighs as it is loaded and configure for travel before choosing a toad. Your MH will not collapse if it is overloaded but you will experience handling issues as well as longer braking distances and accelerated wear on suspension, brakes, steering, etc.
