goboborz's avatar
goboborz
Jumpstart from auxiliary battery
I had to call roadside assistance to jump start my 2008 Roadtrek 170 today. I understand there isa way to jump start from the auxiliary battery from the isolator in the engine compartment using a pair of jumper cables. Does anyone know where to clamp the cables to do those? I've attached a picture of my isolator.
Thanks!
  • I have a different unit- different isolator scheme.
    but most coach batteries are held in place with wingnuts and wingnuts on the battery posts...so minutes to remove ( if you have a slidey under) and carry the battery to the front of the van.
    connect positive to positive. connect the negative to the chassis ( not the battery).
    mike
