prstlk
Jul 30, 2014Explorer
just a DA question regarding dp engine brakes
Not a total dummy but as I was rolling down 299 from the ca coast to redding the war dept. Had a good question I (in all my vast wisdom ?? could not answer.)When going down hill with a gas engine shifting to a lower gear will slow the car, truck, MH. With a dp no. Question here is why a diesel with much higher compression does not work the same. I also have noted that a modern DP would not have a Jake brake but something more complex. If you folks could walk me through that it could improve my stance on the wisdom side with W.dept.
Thanks 4 all
Jw
Thanks 4 all
Jw
