dirtyharryo's avatar
dirtyharryo
Just bought 1992 pace arrow where is front air bag valve
I have looked but can't find them. Front air bag valves for the air bags on the coil springs. Model 33-f I got no owners book with it. Thanks
  • Looked under hood not there. I can't get down to look under it. Will have someone look at it for me. Thanks for reply.
  • Look under the spring at the bottom of the bag and follow the air line to the valve. If no air line then that is the valve is at the bottom of the bag.
    Adding an air line makes it more convenient to check or add air.
  • There is a pretty good chance you are due for replacement after 21 years. There are many tips on here to do it yourself. It takes a lot of pulling to get the old one out and a lot of liquid soap to get the new one in. When I had a '96 P30 I had a central filler with a gauge under the hood. It was a lot easier to check and inflate. That was an after market add-on but well worth it.
  • Could be on the bottom of the bags themselves (bottom of coil springs).
    If an extension has been added, you should be able to follow them from there.
