dougrainer
Aug 29, 2017Nomad
1. On your model, the block heater is a manual cord plug in a outside compartment area in the rear
2. The Roof top antenna system is completely separate from the Sat system. There should be a wall booster up front in one of the overhead cabinets close to the dash area
3. Even as a dealer, we have to buy the complete decal just for missing letters
4. The FAN is for the HDMI switch boxes in the entertainment center and MUST be ON to keep them from overheating. 2014, I don't know if Tiffin installed the ON OFF switch like current models to turn that fan OFF. The switch is inside the rear cabinet and looks like a brown regular house light switch.
5. The shut off valve is located on the outside behind the refer. You remove the outside refer access door to find it. Doug
