Golden_HVAC
Oct 29, 2013Explorer
Hi,
In a Ford, if you shift to 2 gear, the transmission will not try to shift to 1 gear even if it needs to on a steep hill. If below about 35 MPH, leaving the shifter in D will allow the transmission to change to gear 1 if needed to increase engine speed to get up that mountain.
I understand completely the desire to leave the motorhome transmission in 2 gear while driving on a 30 - 40 MPH highway with curves, so it will not hunt back and forth between second gear required to have adequate horsepower to make it up the mountain, and each time you release the gas a bit for a upcoming curve it might be shifting back to drive for only a couple of seconds, that can overheat the transmission. Locking out overdrive is a good idea while the transmission is "Searching" for the correct gear in such a situation.
Also going back down that hill, I hope you used 2 gear, it is steep, and slowing to about 40 then shifting to 2 will help avoid using the brakes, and keep them much cooler.
You might need to wash the radiator to help it run cooler. If you did not hear the engine fan clutch engage (ROAR) on the mountain grade, then you need to replace the fan clutch. It is simple enough, the item between the fan blade and water pump.
While the radiator shield is off to remove the fan blade, washing the radiator from both sides is really easy. Use some simple green or 409, or something that will not attack the plastics and metal in there.
Good luck,
Fred.
PS: With a GM based van motorhome, it should shift from 2 to 1 gear in the 2 position while climbing a really steep or slow grade.
This increases fan speed, and airflow across the radiator, as well as increases HP the engine can make. For a given RPM, there is a maximum amount of HP any engine can make. RV engines can only make about 75 HP at 1,400 RPM, but get well over 150 at 2,200 RPM and upwards of 300 HP at 4,000 RPM redline.
Also try some higher octane gas. You probably will get better mileage, I went from 7 to 8.8 in my 97 F-53 based class A motorhome with a 460" V8.
Good luck,
Fred.
38,766 PostsLatest Activity: Jan 10, 2026
