jspringator's avatar
jspringator
Just purchased 2002 Workhorse P30; front airbag question
I just bought a 2002 Winnebago Sightseer 27c on a P30 Workhorse chassis.
I just drove it from Elkhart IN yesterday. It kept drifting to the right. i discovered the passenger side airbag was 0 and the driver's side was 40. I'm guessing a handling improvement is on the horizon. I will probably have to change the airbags. Not a big deal.
Searches indicate that the proper airbag pressure is determined by a 2 inch distance between the bumpstop and what it contacts. Looking under the front it looks like there are 2 bumpstops. Do I measure the upper or the lower bumpstop?
Does anyone have any experience with setting the front bag air pressure on this thing? I need to get this set before I move to an alignment. Apparently the airbag pressure change changes the alignment.
I also plan on upgrading the sway bar and bushings. Does anyone have any suggestions? Anyone use this? It would save $200 over a Roadmaster.
https://www.brazelsrv.com/roadmaster-spreader-bar-workhorse-p32-wide-track
