- ron_dittmerExplorer III
Bordercollie wrote:
That was my experience, concluding it was better for me to disconnect instead.
Our modern Multi-Stage "Charge Wizard" converter charger depleted the house battery electrolyte level when left unchecked for a number of months. Best to check electrolyte levels and state of charge at a regular schedule to get best useful life out of batteries. - BordercollieExplorerOur modern Multi-Stage "Charge Wizard" converter charger depleted the house battery electrolyte level when left unchecked for a number of months. Best to check electrolyte levels and state of charge at a regular schedule to get best useful life out of batteries.
- DakzukiExplorer IIIf they have a single stage converter, the easiest thing is to disconnect. If plugged in, the batteries will need to be checked regularly. They could also plug in to battery maintainers for the coach and chassis batteries which would be really easy. No disconnecting of anything required. The best thing for them would be to change over to a multi stage converter. They are not that expensive and generally not difficult to install. Mine went into the same enclosure as the old converter.
- ctilsie242Explorer IIIf you have a multi-stage, "charge wizard" converter which can float the batteries, I say plug in. If you have a single stage converter, chuck the converter and buy a real one, or perhaps go with an inverter.
Single stage converters will dine on your battery's soul. - pastorbillvExplorer IIOnly keep plugged in IF you have a battery "tender" that will stop charging and watch for a drop that is enough to have to recharge. My experience is that with older charging units, they'll keep charging and dry-out / destroy your batteries. I also use the "disconnect" switch to stop those tiny drains that will discharge your battery over time.
JMHO! - Captain_HappyExplorerOn my Motor Home when not in use I turn off the house batteries, and on the engine battery I installed a knife blade disconnect right on the battery.
- Cobra21ExplorerOurs is a 1993 Class C. Ours does not draw any power when it isn't used. I keep it unplugged till the day before we leave to cool the frig. and charge
the battery if needed. If we need to keep it plugged in all the time, that tells me that either something is drawing the battery down, or it's time for a
new battery.
Brian - ksg5000Explorer IIIf they have modern multi stage converter then I suggest they keep it plugged in (same as you). I suspect their Class C doesn't have the ability to maintain the chassis battery when connected to shore power - if so they should invest in Trik L Start (inexpensive and easy to install).
- pianotunaNomad IIIDisconnect and add a modest solar charging system.
- ron_dittmerExplorer IIII found it best to disconnect our batteries, but our rig is stored indoors.
38,778 PostsLatest Activity: Jun 10, 2026
