Ivylog
Mar 01, 2021Explorer III
Teleman wrote:Ivylog wrote:
A 2000 Airstream likely has a dumb converter...doesn’t go into float charging. I would just disconnect them, remove the negative cables. AGMs can sit for 6 months without loosing enough voltage to hurt them unlike lead-acid.
There's a switch inside the doorway that operates a relay that disconnects the house batteries. Wouldn't that suffice?
While the relay will cut off most of the power, the relay still has power to it...not a big draw but over months it adds up. You may have a physical/manual disconnect switch closer to the batteries.
