wa8yxm
Apr 01, 2015Explorer III
Ir you coach has a good quality 3-stage converter (Progressive Dynamics with charge wizard,either built in or plugged in,several models) that will do the house
IF it also has a Bi-directional Isolator Relay Device (BIRD) then it will cover the chassis as well.
IF it dos not have a BIRD.. Trick-L-Start should be added to cover that function.
