two_travelers
Jan 16, 2020Explorer
Kirkland motor oil
I see that Costco has their own brand of synthetic motor oil. Like other Kirkland branded items, is it any good? Having a sale on 2 pack of 5qt containers for $25 delivered.
GDS-3950BH wrote:ItsyRV wrote:
Although the ambulance chasers are using the marketing of "obsolete" oil next to current standards as deceptive, in NM they did test the oils and discover the emissions control systems on many modern vehicles using the obsolete oil did cause problems with the emissions controls and may have damaged certain sensors. The long term effects are not know simply because there is no way to go back and test what had happen as nobody can say for sure what they sued last year or the year before. So, it's all based on what can be tested now.
It still does not do away with the fact that it was a frivolous lawsuit as supposedly the oil in question was clearly marked with the grade and other language, like not made for most engines made after 1930 er duh.
The ambulance chasers mentioned fine print and being on the shelf beside oil that had a higher spec. Fine print my rear end. All legalized extortion and DG will settle as that will be the cheaper route, the class will get a Dollar General gift card worth $2.00, and the ambulance chasers will get millions. It's the oil you want to use in the B&S powered lawnmower you bought for $89 in 1990, that burns a pint while cutting your 1/8 acre lot, not what you want to put in your 2020 Ford F-150 LOL.
It's not unlike the McDonald's coffee foolishness. Sure its hot, it's coffee. Just because your an idiot and spill it on your hoohaa, that should not give you the right to perform legalized extortion. I digress.
