dougrainer
Sep 18, 2020Nomad
Are the lids power up and down? If non powered, then check the metal pin switch on TOP the mechanism accessed from on top with the lid open. THAT Pin switch is the GROUND supply for the fan motor. usually you just have to use a 7/16 open end wrench to tighten that pin switch to get a good contac for that ground wire. Doug
38,782 PostsLatest Activity: Aug 31, 2026
