Executive45
Sep 19, 2020Explorer III
Branson N Tucson wrote:
snip/ "Tried checking the fuses in both areas by the brake peddle and in bedroom area. Boy alot of fuses to check. Can anyone help narrow the search area down for the bad fuse.
Thanks for the help.
By checking, do you mean you looked at them or used a meter. A visual can often look good but it's failed. Use a meter for accuracy. Mine will not come on if the vent is not opened. The fact both are not working indicates a faulty wire somewhere so that's a good thing. That is, assuming they worked at some point in time....good luck...Dennis
38,782 PostsLatest Activity: Aug 31, 2026
