Branson_N_Tucso's avatar
Branson_N_Tucso
Explorer II
Sep 18, 2020
Kitchen and Bathroom fans
Have a 2003 Fleetwood Providence that has the Max Air fans in the ceiling fans located in bath room and kitchen ceiling area.(sure older model no remote) Both are not working. They both have fuses located on them. Both fuses are good. There must be a main fuse that supplies power to both. Tried checking the fuses in both areas by the brake peddle and in bedroom area. Boy alot of fuses to check. Can anyone help narrow the search area down for the bad fuse.
Thanks for the help.
  • jdc1's avatar
    jdc1
    Explorer II
    The fans are 12v, so it's not going to be a GFCI outlet problem. Do you have a light near the fan? Is that light on a wall switch? The previous owner may have used the light power to power the fan also. You just have to work backwards, making sure all the wire nuts are tight. I always tug on both wires, to make sure everything is tight.
  • check for tripped GFIC outlets. on a previous MH we found we had one in an exterior storage bay so look carefully.
