msmith1199 wrote:
Teeshot1939 wrote:
I have a faucet and a separate sprayer...not a pull out sprayer model. I have cleaned the aerator without any improvement. Any other suggestions?
If you are getting good water pressure in other places then you have a clog someplace. If it isn't the aerator then start at the top and work your way back. Unhook the water lines from the faucet and get a bucket and turn on the pump and see if the flow is good from the line. If it is, then go buy a new faucet, or take the current one apart and clean it out. If it's not the faucet you're going to have to follow water lines. Maybe you have a kink in a line someplace. But you said it's both hot and cold has low pressure, so since they have different water lines, that tells me it's your faucet.
^^^^This^^^^^
It's very easy to calcium in the control valve(s) but first you need to know if you have good pressure in the lines themselves. I suspect you will find that you do and the fixture is where the issue exists.
