Ivylog wrote:
There are two plugs inside the front cap...you have to remove the arm to get to them BUT they are too big to go through the stem. You have to find a small diameter tube that will slide over the male pin to depress the fingers that hold each wire in the plug... after taking pictures and making a color coded wiring diagram remove all of the wires from the plugs.
Not sure how your pin is held in the arm but my arm has a set screw and a easy out should let you turn it out. Good luck...you'll need it.
Or a whole lot of Really Good Duct Tape.
Best of Luck,
