Golden_HVAC
Aug 22, 2015Explorer
Hemi RT wrote:
I doubt you'll find any C or super C that has air brakes, you'd have to go up to the larger 'A' class to get air brakes. As far as towing 8000lbs I don't think you'll find one. Best to have a look at 'A' class motorhomes.
Some of the Super C's come on 25,999 pound rated chassis, with well over 10,000 pounds of towing ability. They are built on class 6 truck chassis, not a pickup truck. . .
While a class C van based motorhome might only have a 14,000 GVWR, the Super C seems to have 19,500 and above GVWR, and towing ability to match that rating!
As for air brakes or air ride suspension, most Super C's do not have either of those. This is typical of a DP motorhome, not the much lower cost Super C.
I have seen some Super C's built on the F-550 chassis, with a 19,500 GVWR! That size is relatively easy to get into the cab, and has a reasonably soft rear suspension. The motorhomes based on the International chassis will ride like a lumber truck, and could REALLY use air rear suspension.
Air brakes are not a requirement anymore. Hydralic brakes can stop just as well as air brakes.
Good luck finding something.
Fred.
38,782 PostsLatest Activity: Sep 10, 2026
