I changed over to 245 tires many years ago. This last go around I upgraded to G range tires. The 245 tires throw speedometer off about 1 1/2 mph. Current set of tires are truck tires not RV tires. Some choices in these type tires are Goodyear G647, Michelin XZE and Firestone 560 plus. Many others to choose from in the 245/70 19.5" load range G tires. Some have H load range tires.
I have not seen any ride quality problems with these tires. Last time I weighed my MH. Rear axle was at 15k pounds. That puts you right at the edge of the load capacity of 225 tires. You may want to stop at CAT scale and get your MH weighed before you buy tires.
I had my tires done on a
Hunter Force Match HD Balancer last time. Does a great job of making tire run true and balance. I also have
Centramatic on front wheels. They take that last little vibration our of the front end.
My last tires came from
Redburn tire Co. in Mesa. They have dealers all around southwest. Not all stores have a Hunter Force Match HD.
