pauldub
Nov 16, 2018Explorer
pnichols wrote:pauldub wrote:
Half and half for me. I have billies on the front and Koni on the rear. Didn't seem like there would be anything to be gained by putting the expensive Koni shocks on the front.
I assume that the Koni shocks you have in the rear are Koni FSD shocks, as Koni does make regular shocks too.
If you are running FDS shocks in the rear, what size Class C do you have and how is the handling with Koni FDS rear/Bilsteins front?
Yes, I have the Koni FSD shocks in the rear on my 24' Winnie. I haven't found it detrimental mixing the shock brands, both have digressive valving. I have the same chassis as you pnichols, only mine is an '03 with 2018 suspension on the front (thanks to JD's recommendation and encouragement).
38,782 PostsLatest Activity: Sep 10, 2026
