Gdlow
Sep 07, 2013Explorer
Koni FSD shocks
I heard these were much smoother running so ordered and had installed them...they are as hard riding as the Bilstein's...Can they be softened Up???
Gdlow wrote:I missed your reply from the first time around. I'm a bit surprised that the Workhorse has a harsh ride with Konis. My parents have a 2004 Workhorse chassis motorhome. It originally had Monroes on it, which handled poorly and road bad. Workhorse recalled the shocks, and installed Bilsteins. At the time, there was significant discussion here on RVnet about Koni FSD, vs Bilstein, and at that time, the consensus was pretty strong toward Koni having a much better/softer ride than Bilstein. I run FSDs on my coach. I found they have almost no compression damping, which makes for a really soft ride. The handling control is from the rebound damping. Have you ever weighed the coach? Maybe it is just too light for a W22.Daveinet wrote:It's on the Workhorse chassis
My guess is the stiff ride you are complaining about has nothing to do with the shocks. Even though your profile does not state it, I would be willing to bet your coach is on a Ford chassis. If I'm right, that should tell you a lot about why the ride is harsh.
