Jpjlauer's avatar
Jpjlauer
Kwickee Single Step
I have a 2006 Gulfstream BTCruiser. It's been sitting "in storage" next to my house for 6 months. 3 months ago I took it out for a 30 minute "exercise" and had no issue with my electric step retracting when I started the engine. After another 3 months of no use I took it out for another 30 minute "exercise" yesterday. However, this time the electric step would not retract. Does anyone have an idea what would happen to cause it to stop working? I did check the fuse panel and it's not a blown fuse.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Would it not retract at all, or just from the ignition being turned on?
    Mine stopped working from the ignition, but still worked fine from the door. I found a grounded diode/resister inline with the ignition's wire that had broken. I bought a replacement for it and installed it, and that fixed the problem. I think it is a voltage limiter to keep the 14+ volts from the alternator spiking the step's electronics.
    Here is a link to the thread where I was trying to figure it out, and finally got it repaired.
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28038583.cfm
  • Your battery may be just a tad too low for operation. I know nothing about your RV and how it charges but wit mine sometimes when I don't have the solar trickle charger hooked up I have the same issue. Try starting the engine or using a charger overnight.
