dalefuji wrote:
My steps (2) stopped working in out position. When I turn control switch by door on I can hear a small noise, but steps do not move.
If switch is on and door is open the light is on under steps. I check
the three fuses for steps and they are ok. Motor seems stuck.
There is no part number on motor label, just series 32 and the serial
number. This is on 98 Holiday Rambler Endeavor.
Any suggestions???
Cut or disconnect the two wires going directly to the motor. Get out of the way and apply 12vdc from and external source. Reverse the leads for reversing the direction.
No go, disconnect the pin from the step arm and check for jamming.
Remove and recheck it on the bench.
Need motor ass'y..??, lay it on the floor next to your computer and match it up on Amazon with a power window motor for some savings in price.
