ksg5000
Sep 12, 2020Explorer II
As others have suggested - step motors usually last a LONG time. Is the motor dead or have the gears busted? Is the step installed correctly? Do you have binding issues? You can remove a cotter pin and bar which which connects linkage between step/motor .. that way you can manually open the step and determine whether it moves smoothly.
38,782 PostsLatest Activity: Sep 10, 2026
