Rangerman375
Aug 07, 2023Explorer
Kwikee Steps Won't Extend
Currently on the road and the Kwikee Steps on my 2006 Damon will not extend. Everything was working fine on the entire trip. Stopped for fuel and steps extended and retracted just fine. Arrived at campground and steps will not extend.
The amber light under the coach by the step lights up when the door opens so I think that tells me the door switch/wiring is ok, right? Checked the magnet on the screen door and the switch on the door jamb and they seem to be lined up.
Crawled under the coach and tapped on the motor (being careful not to be near the steps) but that doesn't do anything.
Unscrewed the green ground wire from the frame and cleaned it with sandpaper and reattached.
Anything else that i can try to extend the steps until I can get the motorhome where it can be serviced?
Thanks in advance for any advice.
