racerchaser's avatar
racerchaser
Lack of hot water
I have an Atwood 10 gal gas/elec water heater that no longer provides hot water. The water in the tank is hot but it is not getting into the hot water line. Initially, I was using the elec side and the water turned cold so I switched to the gas side thinking that the elec element had gone bad. I got hot water but not as hot as it should be. Not even that has gone away. I flushed the tank and the water that came out was too hot to touch. Have I got a one way valve that is inop or is there an air block? Little tough to evaluate since the tank is not easily observable. This is on a 2008 Itasca Horizon.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Another vote for checking the outside shower valves and the bypass behind the unit if it was winterized.
  • rv2go wrote:
    There is a check valve in the hot water line after it leaves the tank. It does go bad. Mine was located right at the tank. Yours may be there or a short distance away. Since I do not winterize, I just remove the small plastic plunger and replaced the case.
    If you winterize, you will need to replace the check valve in order to keep from filling the tank.
    Hot out on tank (top)........nipple that is screwed into tank is the check valve.
    They are cheap junk..plastic plunger/spring/o-ring assembly. Clog up, jam, o-ring gets dislodged---no hot water can flow out.
    You can gut them and just use the nipple
    You can replace.........and probably have same issue again
    You can gut them and install a shut-off valve on hot out (close when/if winterize) and not have issues anymore
  • There is a check valve in the hot water line after it leaves the tank. It does go bad. Mine was located right at the tank. Yours may be there or a short distance away. Since I do not winterize, I just remove the small plastic plunger and replaced the case.
  • If you have an outside shower check to make sure the valves are closed.
