Class_A_DP_1
Jul 30, 2014Explorer
This is what I have used... http://www.northstarchemicals.com/literature/Premier/PI/Premier%20PB925%20aerosol,can%20PI.pdf
It will work for all sorts of laminating projects also.. counters, cabinets, headliner, etc.
I bought the spray gun, hose, and portable propane tank size container. The stuff is quick to be ready bond, doesn't let go at temperature extremes, easy to clean up any overspray. Get your stuff aligned correctly cause it will not let go once it touches itself. When finished, leave it pressurized with gun attached. Do not turn off the cylinder, do not clean the gun.. just leave it. It can set for years and still be ready to pickup and use. If you turn off the cylinder it will harden in your hose and gun.
Expensive.
Expensive.
38,769 PostsLatest Activity: Jun 25, 2013
