moisheh wrote:
Everyone should be aware that Lippert is the largest supplier of components to the RV industry. They have been buying up smaller companies. They build frames for much of the TT mfrs. These frames like most of Lipperts stuff are junk. Same for their slide outs. Probably cost the mfrs. less than other slide out systems. I don't think you see that Lippert c--p on mid to high end units. Winnie loves their stuff.
Moisheh
What other slide out systems? Lippert is the only game in town.
Once again we read of problems only and want to condemn everything.
We don't hear of the LCI products that are working fine.
If Lippert is so bad why has no competitor step in and taken away market share?
Why is Lippert able to expand into other areas. RV manufacturers are using lippert more not less.
For the record Winnebago is one of the better more financially sound RV manufactures. LCI stuff is prevalent across all RV lines.
What's funny is that this thread condemns Lippert because a motor failed...and the OP could not diagnose and fix problem himself.
Motors fail ... it happens however there is no need to throw Lippeert under the bus over the issue. The entire thread is a lot of LCI bashing based on nothing.
