10forty2
Mar 10, 2016Explorer
Leaf Springs
Anybody undertaken the job themselves to replace leaf springs on their F53 chassis? Considering doing the job myself since I can't seem to get a truck shop to call me back. Is it a driveway job or a...
FIRE UP wrote:10forty2 wrote:
Anybody undertaken the job themselves to replace leaf springs on their F53 chassis? Considering doing the job myself since I can't seem to get a truck shop to call me back. Is it a driveway job or am I looking at a death wish?
10fourty2,
Well Sir, you don't say WHY you're wanting to change them. I'm assuming it's because you're having issues with the present ones, i.e. "sagging" or, not carrying the load or ? I've done a few leaf spring replacements and, also done re-arcing myself. That's not a job for the faint at heart.
But, in any case, if you do take on this project, do take whatever precautions you need to make sure you really stabilize all the components. That is, you will be isolating the chassis/house, from the drive line/differential and while the differential is not nearly as heavy and awkward as the chassis/house, it's still heavy and, due to its design, can get away from you if, not supported correctly.
The springs do more than just support the coach. They're the LINK between those components mentioned. And, even the springs are heavy so, without a doubt, be cognoscente of all aspects of this job. There is a point of "no support vs hanging weight". That is, you need to try and find that spot at which, when you're jacking the coach up or, have supported the coach with all your jack stands/blocks, and are lowering the diff (or front axle if you're working on the front) and, there's no actual weight hanging on the spring connection points, other than the spring weight itself.
At that point, you can then support whichever axle you're working on really good and, then un-do the spring attachment points. That way, if you're replacing them, you'll not have to work that hard to re-align the attachment points with the new springs 'cause you're real close. Good luck.
Scott
