ksg5000
Mar 22, 2016Explorer II
Had similar problem on side window of bunk - the source of the leak isn't as simple as water dripping off your gutter - could be anywhere on the roof and traveling to that location. In my case I first removed the window applied new butyl tape and caulk -- didn't fix the issue. I ended up having to use Eternabond tape to seal the edges and caps of the RV.
If it were me I would take the rig into a place which can pressure test your rig - should determine all the potential leak points in the rig and it only cost about $100. Just my 02.
