SCADAMAN29325
Jan 12, 2023Explorer II
Leak down test on the LP gas system, leak detected.
Next I will be looking to see if I have any issues with LP Gas system. The stove, furnace and fridge appear to be working fine. I have not tested the water heater yet as I have it in the winterized mode.
From what I can tell, I need to put a pressure guage near the regulator, turn on the gas at the tank, then note the pressure, turn the gas off and hope the pressure does not drop. I should have done the leak down test first, before I tested the appliances, but I didn't know about it then and still made it out alive.
Could someone suggest a guage? I think I want to put it on the 4-port tee, maybe on the 1/4" inverted flare fitting. As someone suggested, I may want to rotate the T ports down to where the 1/4" port is pointing down.
Thanks!
Thanks!
