dougrainer
Nov 16, 2017Nomad
HWH jacks have ONLY 1 line per jack. Your system. EACH Jack line goes from the Jack to the JOYSTICK control. NO other lines and they are each separate. NO junction or T. You are confusing the 2 lines that go from the Joystick to the actual reservoir/pump. The Pump has just 1 high pressure line from the Joystick to the Pump. The other line is a larger diameter line and is a LOW pressure line since there is NO pressure when retracting your HWH jacks. Doug
There are 5 Pressure lines. 4 lines for the 4 jacks and 1 line from the Pump to the Joystick.
38,769 PostsLatest Activity: Jun 25, 2013
