dougrainer
Nov 17, 2017Nomad
Gjac wrote:dougrainer wrote:I called a Hydraulic shop yesterday and asked about adding a splice fitting where the line was chaffed through by the frame, and what they described to me was a junction fitting that screwed into the cut line with a retaining nut to secure it. They said it works well with Parker hoses. It was about $30 for the fitting and about $200 for the complete line. They could not install it on the MH so the line would have to be removed anyways. Is this what you are describing? Is there a name for this fitting I can give them?
HWH pumps run at 2900 to 3200 PSI. You do NOT have to replace the complete line. IF the Shop has a tool(I do), you can install the metal flare ends on the end of the bad hose in front of the damaged area(cutting out the hose from the jack to the damaged spot) and then just make a short hose to go from the original to that Jack. Saves time and money. Doug
No, I have a portable Hydraulic Swagging tool I purchased from HWH 25 years ago. The Metal ends are installed exactly like HWH installs them. HWH no longer sells that tool. There is nothing wrong with cutting out the bad spot and swagging a new fitting on the old hose and making a new hose for the length from the Jack to the bad area. Your other hoses are the same age as the bad one. You going to replace those also? If you follow the thread about NOT using the good part of the old hose. If it was a front Jack, I would replace the complete hose from the jack to the Joystick. The Swagging tool allows me to make HWH hoses to whatever length I need. Doug
This is the tool
http://www.hwhcorp.com/mr751000.pdf
38,769 PostsLatest Activity: Dec 31, 2014
