slyone50's avatar
slyone50
Leak in Outside Class C overhang
I have a 2005 Winnebago Itasca Spirit 26 A. I have been recaulking where required, but water seeps through the caulk along the front of the seem of the horizontal piece along the bottom of the overhang. I have no problem with seepage or a leak any where else. First, where does the water come from and second why does it seep. The caulk is what was recommended.
Thanks.
  • Not understanding how there is leaking or seeping that doesn't leak to the inside of the motor home. Where is the leak really showing? Are you saying that it leaks in somewhere unknown and leaks back out the seam that goes across the bottom of the cab over?
  • The leak is on the outside on the underside of the over hang where a metal or acrylic strip goes from one side to the other. There is no leak to the inside of the MH. # 1 and 2 don't apply. #3 Cabover side windows might be it. There are no leaks anywhere else or damage that might be the culprit.
    Thanks
  • j-d's avatar
    j-d
    Explorer II
    Welcome Aboard!
    Best thing is to have it pressure tested, or get a furnace blower and make a pressure tester. Then, soapy solution sprayed from and old 409 bottle will reveal the source. From the inside, you see where the water WENT and what you need is where it entered.
    Do you have a Front Window? If so, Suspect Number One.
    Suspect Number Two, Clearance Lights
    Suspect Number Three, Clogged Track Drain Holes in Cabover Side Windows
    From there, Suspect Pool (no pun...) is any Seam, any Sealant, any Damage
