Suburban52's avatar
Suburban52
Leaking Brakeline on 1997 E450
Hello everyone, trying to find out info before having 1997 E450 class C towed to shop. In my driveway I pushed on brake pedal and lost pressure, leak is on driver side rail in front of rear axle. Hard to see if there is a brake line valve there or where fluid is coming from, has anyone experienced this or know if there a brake fitting in this area. Would like to be more informed before having unit towed to shop. Thanks.
  • Have the front brake flex lines replaced, they can rupture internally and can cause steering wheel to violently jerk right or left with loss of control. Have old brake fluid flushed and replaced to prevent brake fade on down grades. Have entire brake system serviced including calipers, pads, discs, cylinders, adjusters, etc. Have date codes on tires checked and replace tires over five years old regardless of appearance/tread depth. Well maintained brakes and tires are essential to your safety and others on the road.
  • It's extremely common for the brake lines to simply rust out on vehicles that old. While its in the shop, I would have them check all of the brake lines.
    Brian
