Hi. Camping with a full freshwater tank, but it is now leaking. Water is dripping steadily. We have a 3170 Forest River Sunseeker. https://t.co/Jm6AvC1G7z It's coming from the yellow/tan twi...
Any idea what this thingy is, or where the pipes connected to it lead to?
Since tightening the yellowish bit didn't help, the next logical step would be to undo it and examining the washer or O ring that (presumably) is supposed to be sealing the connection, check the connector and plastic body of the doohick for cracks, etc. Unfortunately, from the sounds of things, this isn't practical to do with the tank full, unless you can locate some shut-off valve that stops the dripping.
