jyrostng
Jul 23, 2015Explorer
The dock water inlet has a check valve built into it in the center. When you connect the hose, the pressure forces the check valve open. sometimes that valve doesn't seat correctly when you disconnect the hose and when you turn on the pump, water leaks out the check valve. To attempt to reseat it, you have to bleed off any pump pressure and push the check valve lightly with a screw driver where the hose screws on. Turn the pump back on and see if it still leaks. Worse case, you have to replace the inlet fitting with the check valve.
