turbojimmy
Oct 13, 2014Explorer
Leaky Black Water Valve - what are my options?
Here's a pic of the waste valve on my '84 Allegro:
I have a couple of problems. First, whatever style fitting that is won't accept newer hoses or caps. The only cap that will fit is the original, which has 2 tangs on it unlike new ones that have 4. I tried to use my brother's Rhino hose this past weekend (long story) and it wouldn't fit either.
The other problem is the black valve is leaking significantly. And the old cap isn't holding it back.
I'd like to replace that fitting with one that accepts newer hardware, but I don't know what sort of valve I'd have to get. The gray water valve is new (you can almost see it on the right). I don't have a lot of room to work with on the black water pipe. The valve is installed at the end of a 90-degree elbow. I'm afraid if I cut it off, I won't have enough pipe to install a new valve. Things would snowball out of control from there. I'm wondering if just that valve will come out and I can replace it with a new one? This wouldn't solve my fitting/cap problem but I have to stop that leak at a minimum.
